주요 콘텐츠로 건너뛰기
Repair and disassembly guides for the Compaq Presario CQ40.
35 질문 전체 보기
My laptop screen black but my power button still on
i want to ask how i want fix my laptop presario CQ41 because my laptop screen black but my power button still on...so how i want to fix?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
My laptop screen still on black colour and in every 5 seconds my laptop turn off and then turn on then it continue cycle until I remove the battery and insert it again
댓글 달기
답변 3개
가장 유용한 답변
@shera that could be caused by bad LCD screen. Attach an external monitor and see if that displays properly. Let us know what you get with that.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
you can also check your RAM whether it has been damage
Update (05/02/2018)
I also have the same issue with your own but later changed my RAM , everything come back to normal instantly .
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Try getting a new charger or getting the charger panel replaced.
해당 답변은 도움이 되었습니까?
점수 -1
댓글 2개:
Technical Difficulties why would you suggest to replace the charger if you have not explained to the OP how to test it? What do you refer to as the "charger panel"? This laptop does not have a single part that is referred to as a "charger panel", so nobody will know what to look for.
Your answer is somewhat misleading due to your terminology and not very helpful with the diagnosis or repair of this issue.
Charging port. The thing that you plug the charger in. Whatever. Has charging in the name.
댓글 달기
귀하의 답변을 추가하세요
nurul shahira 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 18
전체 시간: 954
