주요 콘텐츠로 건너뛰기
8.9" tablet, co-developed by Google and HTC. First released in November 2014, running Android 5.0 Lollipop.
29 질문 전체 보기
Nexus keeps trying to start shows the google start up and then nothin
Hi everyone, my nexus keeps trying to start then gets up to the google screen and then just keeps trying to get past that point but cant.... Is this a sign the battery is knackered? It does still charge tho so not sure if a virus has buggered it or what???
Any help would be appreciated
Cheers
Ally
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 달기
답변 2개
가장 유용한 답변
If you have charged it all the way, and it still fails to try to get past the Nexus logo, it could be a battery issue.
To test this issue, see if you can get into "Fastboot Mode" and see how long it stays there.
• First, you have to turn off your device – perform a complete shut down sequence, don’t just reboot your tablet (press Power button and select “power off” or press and hold power key for a few seconds).
• Then, in order to enter fastboot mode on your Nexus 9 you need to press Power, Volume Up and Home buttons at the same time.
• Keep pressing these keys until fastboot mode is being displayed on your device.
• The START option should be listed in the upper part of your screen.
Now, if it goes at least 2 hours without powering off (you may need to touch the Vol buttons once in a while to make sure the tablet doesn't restart or simply goes into power save), you have a software issue.
To resolve a software issue, please be aware that your data likely will be erased.
• if you don't have LTE on the tablet, download https://developers.google.com/android/im...
• if you do have the LTE version, download https://developers.google.com/android/im...
NOTE: Download the last one on the list only, you don't have to download everything.
Follow these instructions to install adb.
https://forum.xda-developers.com/showthr...
Follow these instructions to unlock the booloader from fastboot mode only. Don't do anything else here.
http://forum.xda-developers.com/showthre...
Finally install the large firmware package with these directions using the directions here:
https://forum.xda-developers.com/google-...
NOTE: Start at "Flashing Factory Images".
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
This is a hardware issue with a simple fix. You will need to remove the back cover. Once cover is off, you will need to remove and reseat the larger ribbon cable. This will highly likely fix the issue. The N7 is a beast of a tablet. And had wireless charging back in 2013.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ally Ephraums 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 3,442
