주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1500 질문 전체 보기
Why does MAPS app just show grid lines and not streets and labels?
I have several older 3G and 3GS iPhones that I purchased/picked up for repair and resale however everything works fine on them except the MAPS app. When I launch the MAPS app it just shows a blank page with grid lines and the blue dot for location. But In the satellite mode it shows the correct overview of houses at my location. Does anyone know if this is a software or hardware issue?
Note- I have several other 3G/3GS that DO show the correct MAPS view with streets, names, and labels but most of the units do not.. On the units that don't show the correct view I have restored them to factory settings several time, connected to WIFI, and have the date and time set to automatic. My understand is the data for the streets and labels comes from the internet but nothing is coming over even when connected to iTunes and/or WIFI.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
With older iPhone's especially the 3g, and 3gs models. They tend to have very poor cellular and WiFi connections even if you were say right next to the router. The grey lines you see, is the maps app struggling to load up the map preview. Also remember that if you were to do a satellite image, then it would take even longer to load. Give it some time to figure everything out and it should work just fine!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
The phones are right next to the router and have waited over 24 hours and the image still does not load. And I should have noted that the satellite image loads immediately so it is not a problem, just the Standard view is the problem.
댓글 달기
귀하의 답변을 추가하세요
Ricco 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 2,648
