주요 콘텐츠로 건너뛰기
Apple은 MacBook Air 13"를 2017년 6월에 새로운 Broadwell Intel Core i5 프로세서로 업데이트하여 성능과 배터리 수명을 약간 향상시켰습니다.
421 질문 전체 보기
How to remove a dent from the screen's back aluminium case?
My macbook air 13 inch felt from my lap, and the aluminium case at the back of the screen has now a dent on the corner.
Do you know how to remove the dent? Do I need to disassembly completely?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Do you have AppleCare + ?
If you do Apple will replace the display assembly for a fixed cost which is still cheaper than getting a new display your self and putting it on.
댓글 달기
답변 2개
가장 유용한 답변
Sadly, The design of the lid is not designed to be that serviceable! Here's an older display to give you an idea how yours is constructed: MacBook Pro Retina Display Teardown.
Best to just replace the complete display assembly: MacBook Air 13" Early 2015 Display Assembly Replacement
MacBook Pro 15" Retina Display Mid 2012 이미지
안내서
난이도:
운영
MacBook Air 13" Early 2015 Display Assembly 이미지
안내서
난이도:
운영
45 minutes - 2 hours
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I would not bother. Unless you have serious stoved in the corners or cracked the screen. It is easy to brake other components if you are not experienced repairer. I would put a sticker over it or get a vinyl wrap.
If you have don't have applecare but have full contents insurance on house you might be covered for electronic goods incidental damage.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Max Echeverria 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 2,989
