주요 콘텐츠로 건너뛰기
Part of the Rebel Series, the Canon Rebel T4i is a Digital SLR with an 18 megapixel sensor with an LCD monitor. Also known as the EOS 650D and the EOS Kiss X6i.
Why isn't the image being saved?
I noticed some time back that the image is not saved onto the SD card in spite of everything sounding normal during taking the shot. This ws under normal daylight conditions in the A mode. It started with skipping the occasional image, then it stopped saving any images the next time I tried then I tried taking the shots on the M mode; now it isn't saving the images. This is in spite of the card showing plenty of space.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Thanks. Sounds logical. will try another memory card and took advice and reformatted card. It did seem to start Ok then went funny again. Memory card does seem to be the issue.issue
댓글 달기
답변 2개
가장 유용한 답변
Try another Memory Card. I would think your Memory card is on the way out.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Yes, reformat the memory card. If no joy try fresh one. All cameras tend to run into problems if the battery is diminished. Give it a full charge & see if it operates correctly. Battery & memory card are the first ports of call.
And if you can do it via the options, give it a sensor clean while you're at it.
댓글 달기
I had the same problem and it turned out that my SD card was a fake. It only had a fraction of the indicated capacity and just stopped storing images after it ran full. The menacing thing was that there was no error message. The camera still thought it had successfully saved the images. You could even scroll through them on the camera display. However, after turning the camera off and on again, all new images were gone.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Karim Ibrahim 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 10
전체 시간: 2,132
