주요 콘텐츠로 건너뛰기
Released October 2016, identified by model number RS03QR
I am unable to hear alexa's responce to my questions
I just set up my dot about a week ago. It was working fine as far as we were able to hear Alexa's response. However I just noticed that we are not able to hear it but the light does turn on and if I open my app on my phone I see my question and response. I have re-connected my wifi as well and still no luck.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 4개
Smart speakers are not perfect devices, users face or run certain problems with them from time to time. If you are getting trouble Alexa not hearing your voice-commands or not response to your question then try this one:
- Light ring sholud not be red because the mute switch at the top of the smart speaker has been activated, that's it is not hearing your commands.
- Second reason is due to interference. If echo dot not listen your commands, then place it right location and away from walls and others objects.
- After this problem occuring, possibility that microphone array of echo is malfunctioning.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
First, you want to make sure the volume on the Echo Dot is turned up. If it’s not, use the + and - buttons to control the volume. If it still does not work, make sure no 3.5mm AUX cable is plugged into the Dot (if it is, it will be on the back. Unplug, or make sure the speaker it’s connected to is on and the volume is up). If things still aren’t working, make sure your Echo Dot is not connected to a Bluetooth speaker. You can do this in the Alexa app, or by saying “disconnect my speaker” to your Echo Dot.
Hope this helped!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Have you checked is your Alexa not responding but lighting up? Alexa lighting up in white color but didn't receive your voice commands shows that it were stuck on somewhere.
Try these troubleshooting tips:- https://smarthomepassion.com/alexa-not-r...
Thank me later
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I can’t hear her voice
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Veronica Duarte 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 18
지난 30일: 48
전체 시간: 3,755
