주요 콘텐츠로 건너뛰기
Repair guides and support for desktop PCs manufactured by Lenovo.
97 질문 전체 보기
One half of monitor screen is tinted darker(as if for night)
Right down the middle of my (LG) monitor), one side is tinted darker than the other. During the day the tinted side looks more purple, at night it is a tan-ish tint. It is still possible to see graphics and read text on both sides. My desk top computer is a Lenovo. How do I fix this?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
Hi @kkellys ,
Have you tried another monitor just to prove that the problem is in the monitor and not in the computer?
Can you try a different video cable, just to eliminate it as being the problem as well?
댓글 달기
답변 4개
가장 유용한 답변
Hello jayeff - We tried the monitor on another computer and determined the problem was in the monitor. I had inadvertently made that nasty setting and discovered the fix while investigating other potential monitor settings. I didn't know the monitor had its own settings. Thank you for offering your suggestions!
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Hi! I have the same problem. Which monitor do you have, and how did you fix it? (I have an AGON ag352ucg6)
Hi there - I have the same problem, how did you fix it??
For me, with a Lenovo monitor there is a setting for the screen on the monitor itself ... Text, Web Pictures, something else, Split Screen ... I had set mine inadvertently to Split Screen by fumbling with the "buttons" (places on the bezel that are touch sensitive) and corrected the problem with more fumbling with those buttons.
댓글 달기
this problem is caused by the dead USB or bad driver which cannot be reconigationed by our pc so I can give you a solution for this problem
1. Turn on your pc or laptop in safe mode.( go to setting and go to security and advance setting then select restart)
2. Don't use dead or virus usb or driver.
3. make you pc’s brightness no more then 25%.
4. Give some rest to your pc after every single hour.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I connected a bad USB to my pc and noticed half of the screen is tinted yellowish. Can you provide more details to restart in safe mode?
댓글 달기
maybe the reason is in the monitor settings. enter them (using the buttons on the monitor) and reset to factory settings
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
hey there!! there is a button named as autoset in your display settings, click on the button and set the option to normal, otherwise look for a factory reset setting. hope it helps
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Karen Sigworth 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 13
7일 전: 73
30일 전: 341
전체 시간: 27,400
