주요 콘텐츠로 건너뛰기
Unibody가 아닌 Core Duo & Core 2 Duo 프로세서
375 질문 전체 보기
LED screen for older generation MacBook Pro 17"
I'm replacing the LCD screen on my A1212 MacBook Pro, which is old & becoming more yellowish now. Found a good deal on a LED-backlit screen for A1261 MBP ( model LP171WU4(TL)(A4) ) but not sure if its compatible with my MBP's logic board & GPU.
If they do, what type of display data cable and inverter should I use?
I found these components on ebay for A1261 and will they fit together?
Display Data Cable
A1261 593-0739
A1261 593-0746 B
Inverter
AS0221756E0 612-0033-A
Any help will be highly appreciated! Thanks
Revised for wrong MBP model #
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Your machine is a:
Apple MacBook Pro "Core 2 Duo" 2.5 17" (08) Specs
Identifiers: Early 2008 - MB166LL/A - MacBookPro4,1 - A1261 - 2199
Before replacing anything let's see if we can identify the problem. You may just need to calibrate the screen. Your machine did have a problem with yellow tinting. Please run this test and let us know the results:http://cantonbecker.com/yellowish-macboo...
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Yes it does show yellowish hue, especially to the top and bottom edge of the screen when running the grey image you referred.
Sorry I've misidentified my MBP's model # as A1261, its actually A1212 as a friend point out to me.
So is the LED-backlit panel ( model LP171WU4(TL)(A4) ) compatible with A1212's logic board & GPU unit? If they do will the below data cables and inverter for A1261 fit in? Thanks
Display Data Cable
A1261 593-0739
A1261 593-0746 B
Inverter
댓글 달기
귀하의 답변을 추가하세요
David He 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,164
