주요 콘텐츠로 건너뛰기
Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
89 질문 전체 보기
x-box controller not connecting to console
on/off light flashes but dose not connect to console . was working earlier. changed batteries. did not help
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
My controller is not sync with xbox 360 even I attempted alot to restart, sync button press for both controller and console but unable to find solution.please help even I refixed hard disk also
댓글 달기
답변 2개
You should manually pair the controller to the Xbox. Use this link to help you.
https://support.xbox.com/en-US/xbox-360/...
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
tried your link. did not work.. I have had my x-box 1 for about a yr. the controller was working earlier in the day, turned x-box off tried to turn it on a couple hrs. later. it did not turn on the console. I turned console manually than turned on controller. the on/off button just flashed. changed batteries. did not help.. stumped :(
Well I would just assume the controller is done in for and buy a new one. Microsoft doesnt say much about this.
댓글 달기
i am also having this problem. .with all 4 of my controllers..none of them will connect..fresh batteries nor resyncing did any good. .worked absolutely perfect last night
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
mike 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 22
전체 시간: 3,417
