주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
1.6, 1.8, 또는 2 GHz G5 프로세서
164 질문 전체 보기
Why is my display not coming on?
This morning I tried to use my g5 imac and when I tried to wake it the display was all pixellated and then just went black. My computer was still on but nothing was on the screen. I held the power button down to shut it down and restart it to see if that would resolve the problem but it didn't, the display is still black. The only other thing that is different is the circle light that is on when the computer is on doesn't light up anymore except when I first try to turn it back on. It lights up for a few seconds and then shuts off when the screen tries to come on. What is happening and how can I fix it? Is it my display or just the graphics card? There are no apple stores or people that work on macs where I live and I just need some help.
Thanks, Jesse
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글:
Do you have another display you can try booting to?
If that's good your Video Card is ok, and your problem is either the inverter or display.
Sounds like a bad video card then- however are you sure the rest of the machine is turning on?
I tried to connect it to another display and was unable to get it to work.
Jesse - you seem to have clicked on the "accept answer" link to your own posting. You might want to click on "Unaccept answer" so that it doesn't appear from the main page that your problem is already solved!
1에 댓글 더 나타내기
의견 추가하세요
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
Nintendo Switch 키트 쇼핑하기
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
답변 1개
가장 유용한 답변
In this case the logic board needs to be replaced
Update
It isnt the video card or display or inverter. The 3rd LED never lit up that means you need a new logic board. But first, i would try pressing the SMU button (Below internal power button) just in case the system just needed a reset. You probably already resolved this issue, but im putting this here for anyone else who comes across this problem.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Jesse Anglesey 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 8
전체 시간: 5,335
