주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2261 질문 전체 보기
iPhone Stuck in White Apple Logo.
My iPhone Stuck in White Apple logo. I tried resetting the iPhone , Also Tried restoring the iPhone Multiple times even in DFU mode also. Restoration was successfully completed but device is again showing the same issue. Iphone is stuck in Apple logo itself. in iTunes device is detecting . Device is not under Apple Coverage and i believe if i visits Apple Support then they will advise for a whole unit replacement only. Kindly advise is there any solution for repairing this issue.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
It seems like a bootloop.
Your iphone have problem with the new update, you can download a diffrent version of ios and downgrade it. The new update maby have a problem, and apple will fix it in time, until then you can try do plug your iphone to ituns, go to recovery and download a older version of ios. Like if you have ios 11.3 you see if you can download ios 11.1 or 11.2 and see if your problem is solved.
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
Will it be possible to downgrade. My IOS version is 11.2.5. Kindly advise whether i can downgrade the same?
Here you have a link to ios 11.1
Hope it work out for you!
It is not allowing to installed since the IOS is not signed by Apple. Downgrading is not happening.
댓글 달기
You can easily try this: How to Fix iPhone Can’t Turn On & Stuck On White Apple Logo When Rebooting?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Of course this site is verified, it is free and reliable. But you may not save your date. did you backup your device on iTunes before?
댓글 달기
귀하의 답변을 추가하세요
HASHIR ABOOBACKER 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,428
