주요 콘텐츠로 건너뛰기
Surface Pro 태블릿의 4세대 버전입니다. 2015년 10월 26일에 출시되었습니다.
207 질문 전체 보기
What is the suggested temperature of a heat gun to remove the screen?
Hi, I'm gonna try to open my Surface Pro to upgrade the SSD from 256 to 1T.
What is the temperature I have to set the heat gun to work on the screen removal?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 7
댓글 1개
Hey there. Would love to know how the OP went with this. I'm also thinking of upgrading my surface book 2 256gb to 1TB!
댓글 달기
답변 1개
선택된 답변
@tpcware usual temperatures for this is between 80 and 100 degrees Celsius with 80 degree Celsius being standard. To hot and your LCD will get damaged.
해당 답변은 도움이 되었습니까?
점수 8
댓글 6개:
Thanks for your kind reply. Should I assume you're talking about Celsius degree or Fahrenheit degree?
Because 80°F really differ from 80°C (that is 176°F)...
80°C-100°C.
Make sure not to push up against the glass or it will most likely crack the screen. What I do is cut through the adhesive, maybe some very thin flexible cards will cut the adhesive well.
@tpcware that's a big Duh on my part. Sorry, those temps are in Celsius.
yeah if you have access to a heat pad I'd highly recommend putting the tablet face down on a heat pad that has been set 80 C as opposed to use a heat gun as if you only have two hands then one will be required to hold the heat gun while you're trying to separate the display.
How hot is "too hot" ?
댓글 1개 더보기
댓글 달기
귀하의 답변을 추가하세요
n.carandini 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 15
7일 전: 89
30일 전: 443
전체 시간: 33,622
