The 7th generation Honda Accord
61 질문 전체 보기
My car is throwing a code for camshaft Sensor is it timing belt tho?
My car won’t start checked the code and it said camshaft position sensor as I read up on this I c that some mechanics were saying it’s the timing belt and vents or something like that! I am a female so if I just go take it in to shop I will get taken advantage of if I don’t know what to look for. Someone please help I have breast cancer and I am broke, I need to b able to get to doc appointment and store.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
How many miles on this vehicle?
Update (05/07/2018)
If that is the original belt on there it is very likely failed. I further expect this will be costly to fix as well since almost all Hondas are interference engines and when the belt fails valves get bent and the engine must be disassembled to replace bent valves in multiple cylinders. According to a web site I just accessed Honda only make two non interference engines... the 3.0 Liter and the 3.2 Liter if that is what you have.... you may get it fixed for much less... just the belt replacement.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
180000 miles on the car
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Denice jackson 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 50
