주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Battery Charging Error "7" on Roomba 530
Had an old roomba 530 in storage. Ordered an off brand replacement battery to get it working again. Old battery and new battery give charging error 7 from dock and direct plugged. Even tried charging roomba on a Eufy robot charger threw same error on it after a few hours. It acts like it's charging on all chargers all different ways but then about 4 hours into it it throws the error code. I'm pretty confident it's not the charger. Roomba worked fine with the new battery 1st run. Tried to charge in several rooms so it's not an outlet or climate issue.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
Have the same issue. Did you fix it?
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Fix it myself. Replace D19. Also check R52 and R319. Here is the thermistor schematics http://www.robotreviews.com/chat/viewtop...
No cleaned all circuits and charging contacts still not working
댓글 달기
Try resetting the roomba’s software using the spot and dock buttons. Make sure that the charging and battery contacts are clear and that the battery is seated properly. If that doesn't help, make sure that the battery is suitable for the roomba (which means the battery says it’s compatible with it). If none of these steps help, contact iRobot.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Stephanie Gillham 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 22
전체 시간: 4,854
