주요 콘텐츠로 건너뛰기
Released November 2016, the PS4 Pro features upgraded hardware for 4K gaming and improved PSVR performance.
374 질문 전체 보기
Error code SU-39176-6 after replace HDD
Hi,
I have a problem with my PS4 PRO. I bought new HDD Seagate Barracuda (1TB), download last firmware (954 MB) to my flash USB 3.0 (formated fat32) to folder PS4 - UPDATE - PS4UPDATE.PUP. According step by step processing I get message Error SU-39176-6.
I’ve tried change 4 USB flash drives (USB 2.0 and 3.0), trying download firmware from Safari, Chrome , etc.. the same result.
I have no idea if I have to formated new HDD? FAt32?
I’m frustrated. I’m realy appreciate your help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Have you tried taking the hard drive out and putting it back it. It could be the hard drive either isn't in all the way, or not in completely.
댓글 달기
답변 2개
가장 유용한 답변
Usually HDD do not need to be formatted, PS4 will erase the drive completely in this process, so HDD file system or even partition table is not relevant.
See if the problem persists with your original HDD, also check for Sony support for this error because this error code is very rare and not even found on PS4 dev wiki.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Probbably problem with your hdd. Change HDD!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
tomas mora 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 32
전체 시간: 2,197
