주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz), 2.5 GHz (Turbo Boost 최대 3.7GHz) 쿼드-코어 Intel Core i7 프로세서.
768 질문 전체 보기
How do you make Time Machine only backup Emails on my Mac?
How can I make the Time Machine on my Mac only backup my email database from two different email clients namely Apple Mail and Outlook 2016 for Mac? Is there a possible solution for this, can we make Time Machine do this or if there is some other solution available then do let me know asap. Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
You can make the time machine to backup only your mail folders that are already stored on your mac and are updated daily when the emails arrive. In case you are wondering where are your mailboxes then you can find them here:
Apple mail mailbox location:
1. Open a new Finder window
2. Go to your home directory using the Home toolbar button or select Go | Home from the main menu
3. Open the Library/Mail/Mailboxes directory
This will open up the correct directory where your Mac Mail stores emails. Usually this directory is called Mail and contains multiple sub-folders named the same way as your email accounts. POP accounts and IMAP accounts are named with prefix POP- and IMAP- respectively. Each account folder contains multiple sub-folders for your Mac Mail folders such as Inbox, Sent Items etc.
The folder called Mailboxes is the main storage for your emails. You should copy this folder including all subfolders and files inside to the Windows PC and use it as the Source Folder for the Mac Mail to Outlook Converter.
Take the following steps to open the folder where Mac OS X Mail v1 keeps your messages:
1. Open Mac OS Finder application
2. From the main menu select “Go” item
3. Choose “Go to Folder…” menu item (You can also press Command-Shift-G).
4. Type in “~/Library/Mail/V2” (for Mac OS X Mail 5-8)
or “~/Library/Mail/V3” (for Mac OS X Mail)
This indicating the location of the lication of the Mac Mail v1.0 mailbox. You have to use this folder as the source for the conversion.
Outlook 2016 for Mac database location:
Outlook 2016 for Mac stores messages and other items, such as calendar events, contacts, tasks, and notes, as a SQLite database in the /Users/username/Library/Group Containers/UBF8T346G9.Office/Outlook/Outlook 15 Profiles folder.
If you turn on Time Machine, it automatically makes copies of every file on your computer on a regular basis. If a file gets damaged or lost, you can use Time Machine to browse through the backups and recover the copy of the file.
You can include Outlook data from your Time Machine backups by adding the previously mentioned folder to Time Machine's item inclusion list.
However there are third party apps also available that are capable of backing up emails database of various email clients. One that claims to backup every email client on mac is Mail Backup X: http://www.mailbackupx.com/
Choose your solution wisely.
Thanks
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I tried all the things mentioned above and found that Mail backup x suited me the most as its automatic and completely reliable to use. Thanks for the solution,
댓글 달기
Sorry TimeMachine is not able to resolve to that level but you can still achieve a backup of your mail.
For Apple Mail exporting it to a backup file. Go to the file menu 'Mailbox' and slide down to 'Export Mailbox...' There you can select all or a few of your mailbox's.
For Outlook you can likewise do the same thing exporting your mail file.
In either case you'll need to copy them off your drive or select the external drive.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Matthew Amenta 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 2,360
