Where is transfer box relay location?
No relay - control module behind battery
좋은 질문입니까?
If you are referencing a relatively new Range Rover up to 2012 model year, it does not have a Transfer Case relay in a physical sense. All T-case related functions are controlled by a Transfer Case Control Module. All functions once ran by a relay in older models (Say switching from low to high range) is now transistor controlled by the computer. I would suggest having the vehicle diagnosed by a technician using Symptom Driven Diagnostics (SDD) software to isolate whether the problem is Sensor, Switch wiring or actuator related.
이 답변이 도움이 되었나요?
지난 24시간: 2
지난 7일: 3
지난 30일: 8
전체 시간: 1,560
댓글 3개
Michael West what year and what model is this? What are you referring too with the "Transfer Box relay"? What does or does it not do?
oldturkey03 의
Michael West okay so you found what you were looking for?
oldturkey03 의
If it is a 4wd or AWD and you are talking about the transfer case, it is under the vehicle. They used to be between the gearbox and the rear diff. Now I suspect it is all electronic.
sm_vulkus 의
