주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
211 질문 전체 보기
How can I fix a DS Lite that does not maintain its top case position?
I would like to repair my old DS Lite that felt on the ground many years ago. It still works but now it has a hole which reveals its hinge. The problem is that when I open the DS Lite to play its top case won't stay in position, infact I can't hear any "crack" that usually it does when the top part locks to stay in that specific position.
Which parts have I to buy to fix it?
Here are some images:
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
Nintendo Switch 키트 쇼핑하기
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
답변 2개
선택된 해법
Hi @dadeaka ,
It looks like the upper case will have to be replaced.
Here is a link to the ifixit Nintendo DS Lite Upper Case Replacement guide, which should be of some help.
Here is a link to a supplier of parts for the device. (scroll to the bottom to find upper case parts). It is not a recommendation to use them. It is shown to give an idea of the cost of the part.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Good luck finding a screwdriver that small! Lol
Hi,
I might have the last laugh
Tools required:
Phillips #00 Screwdriver
Tri-point Y1 Screwdriver
Can I just ask, when the OP says the top case doesn't stay in position, do you mean it is really floppy? My DS has no resistance at all to keep the screen in place. I just wondered if replacing the upper case will resolve this issue too? Thanks
의견 추가하세요
Nintendo will fix it for free. The thread is a bit old, but you should call Nintendo support and ask.
https://www.engadget.com/2006/07/21/nint...
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Dade Aka 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 13
30일 전: 48
전체 시간: 682
