주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
Screen won't work after replacement
I replaced my screen on my iPhone 6 plus a while back, and I tried to replace a broken camera on it today. I realized before trying to remove the camera that I had bought the wrong part, but when I reconnected the screen it lit up, but stayed black. I did in fact forget to disconnect the battery when I replaced the screen. I tested it using the old screen, which worked at first, but stopped working after testing it a second time. Is there anything that can be done to fix this?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
There's no image that shows up with the screen, just the backlight turned on
댓글 달기
답변 2개
선택된 해법
Just backlight, confirm the phone boots up by plugging it into computer and opening up iTunes or 3utools it should detect it there.
If it does, then the screen has just gone bad, has backlight but no image.
You already tried unplugging battery and reseating the cables right?
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
The phone does boot up, iTunes recognized it and it will be late when on, but I've unplugged the batteries and reseated the cables both. It is in fact just backlight though, and the screen has worked for months before today, the problem only started after taking the screen out.
Yeah you will need to replace the screen to fix this issue.
댓글 달기
You're sure the cables are connected 100%, this can sometimes happen when they're loose
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Yes, I've unconnected and reconnected the cables multiple times, both with my old screen and the one I've been using
댓글 달기
답변을 추가하세요
Lucas McIntire 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 17
전체 시간: 117
