주요 콘텐츠로 건너뛰기
Second generation of the Fairphone, made by the social enterprise with the same name. Released in December 2015. Model number: FP2-XCVR
74 질문 전체 보기
Can't call or send texts, Radio stuck on off
Hello
I've had a problem where I can't use my sim cards.
At first I thought my phone was stuck on airplane mode but that was not the case.
It seems to be a network issue as both my sim cards are affected. And my phone simply states no network.
I can't seem to switch from 4G to 3G or 2G for one. I click the option but it remains fixed on 4G.
When I make phone calls there's a notice that says Radio Off and so the call does not go through. Hence I can't even call fairphone
The one number I could call led to a prompt.
I called the number to try and have the radio switched on but like the 4G option the radio remained fixed on off.
Also my WiFi works fine it's only the mobile network.
Has anyone had a similar issue? Please help
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 9
댓글:
Having the same problem radio off and airplane mode radio off I know it's not in airplane mode I know how to turn the radio off I have hard reset phone still no luck I don't know this one. I am able to use Wi-Fi internet.
Same problem here How to recover that plz help
Yes please help us same issue with me I'm using redmi note 4
I have same issue LG stylo 5 plus
My phone is similar, broke screen had it replaced but now won't make calls. Every time I try to make call says turn off aeroplane mode even though it's not on. Every other feature on phone works except this. Have I damaged SIM card reader
1에 댓글 더 나타내기
의견 추가하세요
답변 6개
가장 유용한 답변
Hi @dkwene ,
Try starting the phone in safe mode to see if perhaps a downloaded app is causing the problem.
Take heed of the "Please Note" near the top of the page.
Update (03/01/2018)
Hi @dkwene ,
Try inserting a different known working SIM card which uses the same network provider as your SIM cards and see if it works OK. Check if your card(s) work in a different known working same network phone. Basically swap SIM cards between two phones.
If it still doesn't work try a factory reset and then check if it works OK.
Be aware that a factory reset will erase all your data and downloaded apps, it will restore the phone to its' factory default condition. It will be like when you first bought it.
Before you perform a factory reset, backup the phone first using the phone's backup feature. That way if the reset solves the problem you can restore the phone, with all your data etc, from the backup that you made, using the phone's restore feature.
If it still fails after the factory reset, then the phone is faulty.
As it is new, consult the manufacturer's warranty statement, usually found with the documentation that came with the phone or in the User Guide as to what you have to do to make a claim for a manufacturer's warranty repair, replacement or refund
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Hi jayeff I started it on safe mode and it still has the same issue. Might you know a way to turn on the radio?
의견 추가하세요
Did you turn on your radio while you were on call before this problem happened?
I tried turning on the radio while on call and it gave me this message, “Please do not turn on fm radio during a phone call".
I guess it causes some problems that's why instead of the usual message of “Cannot start radio” or “Can't start the service” it displayed this message “do not turn on “.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Pull Sims out and clean them off with a Qtip
Then blow any dust out of where the sims go
Try that first
I once had the same problem turned out to be lint in the Sim Card Tray
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Still no luck, I've tried switching round the sims cards and also just having one some card in. It's a new phone I've had it for about a week. I've attached an image showing the service status which is what I'm having a problem with the most. Still unsure how to switch on the radio
If I update my android version from android 8 to 9 does this process will solve the problem.
What do you think bro if you read message me in
supermanbhardvaj2@gmail.com
@dkwene hi Dianne k ,do you have hey Google radio,turn it on ring the numbers when connected turn off as normal and after all these radio off numbers TURN off your Google radio ,
의견 추가하세요
I just experienced it now…..but then I just restarted my phone..and the network came back
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
Sim not work network problem
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
I did ,it was my google radio, whilst in the middle of phone call I switched off Google radio at the plug after that couldn't connect because of radio off ,so switched on my Google rang the number when connected turned off my phone first then Google radio - solved
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Dianne K 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 13
7일 전: 135
30일 전: 734
전체 시간: 17,643
