Crank shaft position sensor replacement
how do i change the crank shaft position sensor on a 1997 chevy cavilier 2.2
좋은 질문 입니까?
좋은 질문 입니까?
If you are facing the car the crank position sensor will be on the left side of the engine, down low on the crank case. It will be to the left of your oil filter if you are facing the left side of the engine. Crank position sensors are typically easy to unscrew and change. Be sure you create a good seal when putting the new sensor in to avoid vacuum leaks.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 7
30일 전: 22
전체 시간: 658
