주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Replacement Battery Losing mAh Fast
I installed a new Battery into my iPhone 6 about a week ago. Now, usually this wouldn't bother me, but the battery reading software when I first installed it said it had 1750 of 1810. Which is not much of a difference but still a fluctuation for a battery. Now, 14 cycles later it is reporting that it can only handle 1650 of 1810. And I will unplug the phone and plug it back in and it maybe will go to around 1670 and sometimes lower to around 1610. Is this normal to see in a battery for fluctuations in capacity? Or should I order the warranty replacement?
It was a company off of amazon, probably not the best quality battery.
https://www.amazon.com/gp/product/B0769H...
Recently I replaced the iPhone 6s Plus battery, but ordered the parts from iFixit, and it has a maximum capacity of 2865 of what it should only have 2750 mAh.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Batteries are strange beasts; you can't get too caught up on what the exact capacity is at the outset. However, capacity trending down at a rapid pace is cause for concern. You are already down to 90% of capacity within a week.
You should contact your seller and see what they can do for you. They may be willing to replace it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Figures, I thought something was up. Thanks for the help. The seller did agree to send a replacement, I just wanted to make sure I was not over-worrying and making them replace a perfectly good battery.
댓글 달기
귀하의 답변을 추가하세요
Noah Smith 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 443
