주요 콘텐츠로 건너뛰기
Repair and support for ceiling-mounted bladed fans.
31 질문 전체 보기
My Ceiling fan only make humming sound but not moving, Light works.
Ceiling Fan light is working but fan only making humming sound but not moving? I have changed capacitor, checked pull switch and forward-reverse switch. Don,t know whats the issue here.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 3개
가장 유용한 답변
It can also be a problem with the switch connection make sure all the wires are connected properly and make sure the switch is working 100%
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thank you. I'll look into that also.
댓글 달기
Does it spin easily by hand when off? When on and humming, try and get it spinning by hand. Does it take off and start spinning? If so your capacitor may be bad out of the box (rare but happens) or might be the wrong capacitor. If it doesn't, or doesnt spin freely like it normally does, then the motor might be bad/have bad bearings.
해당 답변은 도움이 되었습니까?
점수 1
3 댓글:
I have this problem. My fan spins easily by hand. Motor hums and changes when speed is changed but fan will not run. It has been this way for a year. Last year I went outside came back and fan had started working. Just turned it off to dust and it will not run. Still spins easily.
@fredric2 sounds like you need to open it up and check the capacitor. Alot of fan capacitors are square with up to 5 wires.
Thank you. That is what I was thinking. Nice to get a second opinion.
댓글 달기
I don’t think it is a switch problem. When I change speeds I can hear the hum change. I took the light kit off to look at the capacitor. I ordered a new capacitor and like magic the fan started working again. I have a new capacitor. Next time it doesn’t start I’ll replace it. Until then ‘if it ain’t broke’.
Thank you for your guidance.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I found my direction switch was the problem. I can switch directions a couple of times and the fan will start working.
댓글 달기
귀하의 답변을 추가하세요
Vikram Raj 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 44
전체 시간: 683
