주요 콘텐츠로 건너뛰기
모델 A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 또는 3.8 GHz Core i5 또는 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K Display. 시스템이 매우 유사하므로 이전 iMac Intel 27" Retina 5K Display (Late 2014 & 2015) 안내서를 참고하십시오.
293 질문 전체 보기
Any potentail for upgrading GPU cooling?
How is the cooling configured inside the 2017 27" iMac?
Is there a heat-sink on the GPU?
Is there space to attach one if there is not?
Are there any potential options to improve the cooling for any of the core components (i.e; replace thermal compounds with higher performing ones, attach heat-dissipation to GPU/CPU that currently lack any)?
Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Lets try this, Install this app: TG Pro it will allow you to see the internal thermal sensors and whats happening with the fan. Once you have it running take a snapshot of the main window when its at a point you are getting concerned of the running temp and paste it here for us to see 기존 질문에 이미지 추가하기.
As far as your direct question your system has two heat sinks one for the CPU and a second of the GPU. Both feed the heat to a fin system for the fan to extract the heat and push it out through the back of the system. I would leave the cooling system alone as it as its quite good, unless you have something show up under TG Pro. Then we can see what actions would be needed then.
The simple steps is to make sure the vents along the bottom and back are not blocked so the system can breathe. Also make sure you've not over taxed the system running processes which are over stressing it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I will give that a shot and share what I find as soon as I have some results.
However, my question is less aimed at fixing an existing problem as it is in preventing a problem. I use my iMac a great deal for Photoshop/Lightroom and the like; but, I also boot into Windows fairly often to play games.
The impetus for my question is in trying to improve duration for peak performance by reducing thermal throttling (if it ever occurs).
댓글 달기
I think 'thermal throttling' occures when the GPU reaches 80°C resulting in lower fps (i did quite some testing now). I would like to improve the cooling capabilities as well and thought of this: The foot/stance of the imac is an external heat sink of some kind. The exhaust is venting the hot air directly onto it. Maybe one could add a fin/heat dissipation thingy with thermal glue to it. Right above the hole for the power cable. Then use a quiet fan.
Not sure hot to measure the success though. I guess a GPU temperature of 77° C with 300 less RPM on the main fan would be an improvement. It'd go from "noisy as !&&*" to "I can live with it".
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
How about running TG Pro so we have something to work with. The link is in my original answer.
댓글 달기
귀하의 답변을 추가하세요
Soli Ramsdell 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 1,699
