주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
966 질문 전체 보기
Help me identify this part
Hi, while replacing screen op Iphone SE (5S) I have a part I dont know where to put. I replaced a completely broken screen so the part comes from eather front facing camera or home button. The part is small from rubber and quite flexible.
Rubber part foto1
Rubber part foto2
Many Thanks!! I am waiting to put it back together until I know where it goes.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Hello Alexander, Sam is correct. Your phone will be fine without the light sensor gasket.
This part often falls off during screen replacement due to the fact that it sits in a perfectly-sized slot on the original lcd frame, but may not fit in the replacement lcd frame. Occationally the molded plastic parts on an aftermarket screen will be off by a fraction of a millimeter here and there. I see this often right where the gasket fits between the lcd frame and the front camera catch.
So if you want, you can open the phone again and install the gaskey where is belongs. However, if the space looks too small, just leave the gasket out. You are better off fitting just this light sensor into an over-size space than you are trying to force the sensor with gasket into an under-sized space. Only put it back if it looks like it will fit snugly - don't risk smashing the sensor.
댓글 달기
답변 1개
가장 유용한 답변
Hey Alexander! That looks like a gasket that belongs on the front panel sensor assembly (the front-facing camera, ambient light sensor, and microphone cable you pulled off the top of the phone). This particular rubber bit belongs on top of the ambient light sensor. We don't have a great image for you, but I found this unsourced one in a broken link on Google images.
Your phone will likely be fine without it, but it may struggle in dimming when you make calls and other ambient-light issues, since this helps shade that sensor.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Alexander Fdgn 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 121
