LG 60UF850T lcd tv screen flickering
My lg 60UF850T television s screen keeps flickering. Also in the top right corner seems to be some bleeding. Can this be fixed?
좋은 질문 입니까?
좋은 질문 입니까?
@piddo any bleeding is usually caused by a bad panel. This cannot be fixed but would require a new panel.Post some images of what your display shows. The same with the flickering. This can be caused by a bad main board, bad power board (backlight supply) a bad panel and many more things. Besides the pictures of the Panel you could also post pictures of your boards with your question. Use this guide 기존 질문에 이미지 추가하기 so we can see what you see.
해당 답변은 도움이 되었습니까?
Sorry mate. I’ve been super busy but here’s a short 10 sec video showing you what it’s doing. Thanks again.
This could simply be a bad Main board. I'd be looking at the boards for any obvious damage.
I couldn’t tell if anything was wrong. It all looked ok to me. Hmmmmm.
No. I sort of gave up as I had another tv I could use. Would love to fix it though.
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 4,898
댓글 6개
I fixed mine , was the t con board, I had the same problem .
matias.palominos 의
Were you able to fix your tv? had the same problem as your tv
Jhayxian 의
Adam Piddington 의
i was able to fix mine.
Jhayxian 의
I have the same problem on the 32 inch LG
Simasiku Aibalelo 의
댓글 1개 더보기
