"No bootable device -- Please restart system" - Nothing works!
Hi everyone! Yesterday when I tried starting my laptop (Toshiba Satellite S55-A5295), I got the error "Checking Media - Fail " and "No bootable device -- Please restart system." This seems to be for no reason at all (I haven't downloaded anything recently or made any changes), however my hard drive has been making some loudish noises, so I'm not sure if that's the issue. I've read multiple forums and have tried everything I could find, but nothing has worked.
Here's what I've tried:
1. Opened up laptop and took out hard drive, battery, then plugged everything back in
a) removed battery, held power button 20 seconds, replaced battery re-connected to AC adapter
2. Tried hitting the reset button
3. Checked BIOS boot settings
a) changed Boot Mode to CSM Boot, and back to UEFI Boot
b) tried moving around the Boot startup (HDD/SDD) to the top
c) tried loading Setup Defaults
Is my laptop dead? I don't have a recovery CD and am not sure what else I can do. All of the videos and forums seem to suggest the same BIOS boot setting changes. Please help!
좋은 질문 입니까?
댓글 3개
Do you have access to the CMOS battery? If you disconnect the ac power, then take the laptop battery out, then find the CMOS battery on the board (its a circular battery about the size of a small coin), take that out for about 30 seconds then put it back in and everything else then try, it could help, after trying that let us know if you have the same results.
James 의
Hi @kmkz, I tried taking out the batteries (and the small coin like battery), and got the following screen:
" RTC battery is low
Press [F2] key to set Date/Time."
After setting the date and time in BIOS I again got the "No bootable device -- Please restart system" error.
@salmonjapan Can you please explain how I can check and test my SSD? I can only access BIOS, but nothing else will start up.
I am using Windows 8.
Thanks!
Jennifer 의
@Besi Kateshi
check if hard disk is detected. what model is your laptop?
you should open new question btw.
Augustine 의
