주요 콘텐츠로 건너뛰기
Can be identified by Serial Number: 31.2000.2338851 Manufactured by Keurig
20 질문 전체 보기
Keurig K10 Mini brew switch intermittent problem
The brew-switch on my K10-Mini does not always change to flashing red (stays flashing blue) when I push it. Pushing multiple times normally solves the problem, but it is getting worse. The machine is two years old and brews one cup per day on average.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Sounds like you might need to descale your machine. Crap builds up inside the boiler and prevents correct operation. If you have your manual it will describe how it is done.
Otherwise go here
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Thanks. Could you please explain how scale in the boiler could prevent the heater from switching on.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mike Webb 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 150
