주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The RIDGID R84015 X2 is an 18v, 1/2 inch chuck, cordless drill.
Bit won't come out of the chuck.
I used my drill today and I went to drill a into a piece of brick and the bit went back into the drill somehow. I can open and close the chuck but the drill bit will not come out. When I push on the end of the chuck it goes into the drill, it has a lot of movement.
I tried everything to try and get the drill bit out, nothing works, I don't understand how it could get stuck in the drill when I can still open and close the teeth to the chuck. Thanks.
Joel
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
선택된 해법
Open the chuck as wide as it will go. Hold it with the opening pointing down and tap the chuck with a small hammer till you can either grasp the bit with a pair of needle nose pliers or it falls out.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
The bit you were using got jammed into screw that holds your chuck in place.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If you can still grsp the end of the drill bit with a bair of plyers bring the jaws of the chuck to the edge. Place a washer over the bit. Clamp a pair of vise grips on the bit and then turn the chuck out. The washer is just to protect the jaws. you might need to turn the chuck with a pair of channel locks.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Joel Silva 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 16
전체 시간: 8,133
