주요 콘텐츠로 건너뛰기
Surface Pro 태블릿의 4세대 버전입니다. 2015년 10월 26일에 출시되었습니다.
Screen Replaced but touch screen doesn't work
So I just replaced the screen on a surface pro 4, however the touch screen doesn't work when i use my fingers. It works fantastic with the pen and with the keyboard, but not when I use my fingers. The cables are seated properly so I don't know what the issue could be.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Did you double check the digitizer board behind the screen to see if the ribbon cables are fully inserted and clipped in?
이 답변이 도움이 되었나요?
점수 2
댓글 8개:
yea they're all seated and everything. the digitizer works, the screen cuts on and everything. i just can't use my fingers.
The touch screen is defective on the screen, which is pretty unfortunate.
I'm guessing you already checked the touch screen cable that plugs into the surface logic board and the mini board on the screen.
aww man! I did check the cables on the ntrig and the other cables as well. they're all seated properly. im going to do another check and then have someone else look at it to double check. i haven't sealed it yet so that's the good news.
Just checked it, the emi shield was messing with the touchscreen connector. thanks so much for all of your help!!
I have a similar problem, I replaced my screen on SP4, everything seems to be connected properly, I checked various times but half of my screen does not respond to touch, any ideas?
댓글 3개 더보기
댓글 달기
답변을 추가하세요
LMJ 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 7
전체 시간: 1,692
