주요 콘텐츠로 건너뛰기
Samsung Galaxy Light는 2013년 10월 T-Mobile용으로 출시된 Android 기기이며 GPS, microSD 카드 슬롯 및 8GB 메모리를 포함합니다.
12 질문 전체 보기
Why is my phone restarting only to opening title screen, then freezes
When restarted the phone will only open up to the carrier id screed past the Samsung opening bell sounds. Unresponsive. Apps began to shut down after I did updates of apps I've been using. How can I save my photos & music?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Turn on and use safe mode
Safe mode allows you to turn on the device with third-party apps disabled. Then you can easily uninstall apps that may be causing a conflict or software problem.
Turn off the device.
Press and hold the Power key for one or two seconds to turn on the device.
When the Samsung logo displays, press and hold the Volume down key until the lock screen displays.
Uninstall apps that are causing a problem.
From any Home screen, tap the Menu key.
Tap Settings.
Tap the More tab.
Tap Application manager.
If necessary, swipe right to the Downloaded screen.
Tap the desired application.
Tap Uninstall and then tap OK.
Turn off safe mode
Press and hold the Power key.
Tap Restart. Tap OK.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ruth Goddard 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 71
