주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
Replaced wifi/bluetooth antenna, and now I can't get back panel on
I replaced the antenna, and put a new battery in. Everything fit back perfectly and was reconnect. When it came to putting the back cover panel back on, it wouldn't go or slide back into place fully. How do I remedy this? Any tricks or tips would be appreciated. I don't want to break it, so "force it harder" is not a good answer.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Push the battery against the phone more, maybe it's not fully seated well with the adhesive behind it.
Usually putting the rear cover on isn't a issue on original back covers unless the battery has expanded.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Wyatt Dolezal 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 32
