주요 콘텐츠로 건너뛰기
The third generation Audi A6 model was introduced by the German manufacturer in 2005. Based on the Volkswagen Group C6 platform, the new A6 featured the same Audi-styled single-frame grille and a revised suspension.
10 질문 전체 보기
Audi A6 2006 suddenly stopped
My Audi 6 2006 suddenly stopped
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Since the symptoms are not clearly stated, it is difficult to point out the issue in the first place. It could be a bad ignition module or ignition switch. Sometimes the engine is absolutely fine but won’t start. In such cases, it would be best to leave alone for a couple hours and try again. Sometimes, the car would turn over but doesn’t start, eventually the engine would fire up. This means CAMSHAFT POSITION SENSOR requires replacement. However, to properly identify issue, it would be better to take your Audi A6 2006 to the nearby autobody shop in Greensboro.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Chris A 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 7
30일 전: 36
전체 시간: 1,386
