Water damage; no screen, no chime, fan spinning + green charger light
Issue here with an early 2015 Macbook Air A1466 [820 00165 A]. Started with some liquid damage around CPU area, when after no sign of life, just a charger light.
- Measured all "always present" rails on the logic board, all are in their respective Volt range from S5 to S0 (including Vcore)
- Gently cleaned the whole board with a soft toothbrush and 93% alcohol
- Fan is spinning and sensors seem to be working fine (spinning after I cleaned with alcohol)
- Charging light shows orange light when battery is disconnected (green when connected)
- No chime
- No screen
Already went to an Apple Reseller here in Brazil before I started testing myself but they just replace parts, not component level at an equivalent of nearly $600.
To me this seems like a CPU issue, but can I test this? And if the CPU is really fried, can it be replaced in a repair shop that has access to a hot air station so they can change the CPU/GPU from let's say a donor board?
Many thanks,
Nick
좋은 질문 입니까?
댓글 2개
I know @refectio can do microsoldering. maybe he can help?
Aiden 의
@captainsnowball I think @reecee is more suited for this :>).
Minho 의
