주요 콘텐츠로 건너뛰기
Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
61 질문 전체 보기
My IPAD got wet so it doesn't start after sitting in rice for 3 days.
My IPAD got wet and now won't start after sitting in rice for 3 days and in silica gel. what should I do? Is it repairable? Where should I take it? It was a gift that came with a warranty that I never used so I don't know how long the warranty is for.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Rice does not work! save it for eating. although not that used rice...
anyway,
you will need to take the whole ipad apart, which this guide mostly covers, iPad Mini 3 Wi-Fi Logic Board Replacement
and then clean it using the directions in this guide: Electronics Water Damage
also, the battery MUST be replaced. water does not like batteries. iPad Mini 3 Wi-Fi Battery Replacement
iPad Mini 3 Wi-Fi Logic Board 이미지
안내서
난이도:
어려움
iPad Mini 3 Wi-Fi Battery 이미지
안내서
난이도:
어려움
2 - 3 hours
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
You can check the status of your coverage on any Apple product by entering the serial number Here:
https://checkcoverage.apple.com
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
I typed in the serial number from the box and the IPAD and got the response that it was not recognized. now what?
Try it again, I just put mine in to test it and it worked fine.
댓글 달기
귀하의 답변을 추가하세요
bralrn 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 19
전체 시간: 4,835
