주요 콘텐츠로 건너뛰기
JBL Flip 4 portable speaker. IPX7 waterproof bluetooth dual driver speaker that won the CES Innovation Award 2017.
JBL FLIP 4 water damage and glue problem?
Hello!
I have submerged/tested my speaker in water at home (considering the certification). The JBL then got dried out but water under the power button was apparent in form of drops, which then also condensated and after about 24 disappeared. Is this normal behaviour for this speaker as it is IPX7 certified. Where might the water come from. I have only seen one video in You Tube where the same problem is regarded. (picture attached for my speaker)
Blue color is the norm whereas white is condensation.
I have a clue that it might leak from one of the passive radiators. Both of them seem to be poorly glued on the body of the spaker, BUT I have checked other speakers at the store, where I bought it and they too seemed to be rather poorly glued on, but maybe not as much as mine. Or it could just be condensation even though I don't think so.
The speaker still works fine. I had the opportunity to send it for "Repair", but this means that I will have to wait about a month for nothing, probably.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 17개
Water leaked into my speakers half a year after I bought it then it stopped working warranty(K-Four warranty) doesn't cover water damage and there are no replacement baterries in my country (Cambodia).
Excuse me but where did u go and fix your jbl because my problem is that the water went in the charging area and the spraker did not worked anymore
Did you close the charge port properly
I got one and I haven’t added like water to test it out but should I or is it risky?
Don't risk it!
댓글 12개 더보기
댓글 달기
답변 2개
선택된 해법
It’s nothing to get worried over I put my flip 4 in water then noticed this too water has not got in to the speaker the button is protected by a rubber piece that keeps the speaker waterproof and then a little bump where the power button is and there is a little space where water can get in but that is completely normal
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
This is normal for the speaker to get moisture inside the Light indicators It’s not water damage
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
yavor minchev 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 29
전체 시간: 12,045
