Changed out the EFI chip on this MacBook Air and now it won't power on
I recently bought an Apple MacBook Air, and stupidly didn't check to see if there was a firmware password on it or not. The old owner doesn't know the password. So, I purchased a pre-loaded EFI chip for this specific model (a1466 EMC2632) and followed a tutorial on youtube on how to replace the EFI chip with a heat gun and flux. I did so, and I reassembled the logic board and doubled checked to make sure every cable was plugged in properly. I plugged in my MagSafe charger and it doesn't show a green light. I pressed the power button and nothing came on, no sound, no battery symbol.
I thought maybe the BIOS chip was bad, but would that prevent the entire computer from powering on? The battery is still good, the cables are all plugged in securely. I don't know what exactly could be causing this, as I didn't do anything other than heat up the EFI chip and replace it with a different one (which is from the same model MacBook Air). I know the charger works properly because it charges my MacBook Pro just fine.
any suggestions? Is there something that could go wrong in re-mounting the logic board?
좋은 질문 입니까?
댓글 6개
Did you ever get anywhere with this? I just changed a chip on mine and my charger does have a orange charge light, but doesnt power on. Not sure if my battery is dead or I may have to try goin back to my old chip. If you were like me and got the chip on eBay from china I guess being defective is an option...I used a reflow oven so pretty sure nothings out of place.....
St Kittz 의
If the chip is not soldered properly, the Mac will not power on at all.
Allen 의
Did you ever figure out what happened? I tried doing the same process with my macbook pro but unfortunately the laptop wont boot up. Right now I have my laptop charging. Whenever the white light blinks while being charged I hear a noise from the hard drive and the fan turns and that process repeats itself. Any suggestions?
Jonathan Gonzalez 의
Hey there, Did you figure out what the issue was? I am looking to do the same thing but not sure about how to best remove /replace the EFI chip.
Who did you buy the EFI chip from on Ebay?
About to buy this one,.
https://www.ebay.com/itm/BIOS-EFI-firmwa...
Max 의
Is there a site I can get the bin file to program the chip?
Recently replaced the EFI chip for iMac a1311 now screen will not come
christopher.gatewood 의
댓글 1개 더보기
