How do I connect the SSD externally?
I want to remove the SSD (SD5SL2-512G-1205E) mounted in my system so I can use it externally.
Any methods? should i buy a adapter?
좋은 질문 입니까?
좋은 질문 입니까?
OWC makes a special external case to house the custom Apple SSD: OWC Envoy Pro
해당 답변은 도움이 되었습니까?
but it's to expensive :( i just want to take out data
If you look on eBay you might find one for sale used if you can find a friend who has the same model as you (Model Identifier: MacBookPro10,1) you could swap out your SSD for his and then back it up onto a USB flash drive.
Otherwise, I have no magic here. Apple uses a custom interface on their blade SSD's so you are stuck.
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 284
