Model A1199 / 2, 4, or 8 GB capacity
99 질문 전체 보기
Itunes cant recognized this iPod at the moment
Itunes displays this error message:
"Itunes cant recognized this ipod at the moment"
Weird?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
선택된 해법
Try using different usb ports. All usb ports carry 5 volts. Not all carry enough current to charge your battery. If that doesn't work try a different cord. If that doesn't work look for debris or bent pins in your charging port. Remove any debris if found. If you find bent pins there is a replacement here. The replacement part requires soldering.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Left the ipod connected to itunes for some time and it installed "apple device" ! But still nothing showed up on itunes or my computer.
Btw does that connector fit 5th generation nano?
의 답변
If the battery doesn't have over 3 volts it might not show up. The connector will fit a 5th gen Nano, but you have to add a 68ohm resister to one of the pins. The pin out to the connector is here http://pinouts.ru/Devices/ipod_pinout.sh... at the bottom of the page is what you need to know for the 5th gen nano.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
BOL 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 5
전체 시간: 1,200
