Kernal_Task taking too much CPU Usage (Around 300%)
Please advise me a solution for below report:
좋은 질문 입니까?
좋은 질문 입니까?
Restart your system in Safe mode to see if that fixes things (review the Apple T/N below). If not you'll need to boot up under the recovery partition to run Disk Utility. I often find I need to run Disk Utility from a different boot drive so you might want to give that a try if you have a MacOS bootable drive.
해당 답변은 도움이 되었습니까?
Dan. The answer is good as far as it goes, but what to do after running Disk Utility? First Aid, I assume?
Yes, its assumed.
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 126
