How do you read a panic report?
My laptop keeps crashing. I've had the GPU replaced before as it used to happen more often, but it will work for a while after the GPU replacement and then start having the exact same issue.
It will randomly shut down. I've noticed it happens more when I use the USB ports to do large data transfers more often then when I'm doing anything else. I'm attaching a copy of the last panic report. Any help will be greatly appreciated!
Update (04/04/2018)
Just a little added information, right now is the system I have two drives that are fusioned into one. I have a 512GB EVO drive and a 2TB rotational in the DVD drive bay. Both drives have tested fine by themselves and give me no issues.
I have also tried installing the operating system on just the SSD to see if that was an issue but it still happens. I've had two different sets of RAM in the unit and still have the same issue.
The computer is a 15" MacBook Pro 2012 2.6 i7 with 16GB RAM and the two drives that I have mentioned above.
좋은 질문 입니까?
댓글 1개
Your systems specs: MacBook Pro 15" 2.6 GHz i7 (Mid 212)
Dan 의
