주요 콘텐츠로 건너뛰기
The Xbox One Model 1698 Wireless Controller was released by Microsoft in 2015 alongside the Model 1697 controller. This controller is similar to the Model 1697 with internal modifications. It has more features than a basic controller, such as, removable thumbsticks and metal D-Pad buttons. The controller is primarily designed for console use, but is PC compatible.
62 질문 전체 보기
Elite Controller won't connect (might be liquid damage)
I was at a friend's house the other day and spilled a little mtn. dew on my controller but it seemed fine. I dried it off and checked that it worked. When I went to use it a few minutes later it wouldn't connect to my Xbox. The controller will come on but not connect to Xbox. Tried a USB cable connection and even a different Xbox but nothing. After a while, the Xbox would try and update the controller but it would say an error occurred. Any ideas? Even tried it on my pc but still nothing.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi @rebridge ,
As you know liquids and electronics and electricity are not a good mix.
The liquid causes corrosion and provides circuit paths for the electricity which were not in the controller's operating design and could damage the components.
First do not turn on your controller so as to minimize any further damage.
Then you need to dis-assemble the controller and clean all the affected parts using Isopropyl Alcohol 90%+ (available at most pharmacies) to remove all traces of corrosion and liquid. Do not use "rubbing alcohol" as in some cases this is only 70% or less, can contain scents and is not as effective. If you do have to use it, check the label to verify the amount of IPA.
Here's a link that in general describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the controller might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your controller.
Xbox One Elite Wireless Controller Series 1 (Model 1698)
If this process seems too daunting, take your controller to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thank you so much!
댓글 달기
귀하의 답변을 추가하세요
Robby B 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 19
전체 시간: 3,414
