주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2554 질문 전체 보기
Only charges when turned off.
I'm currently doing board level repair on it, replaced the transceiver for cellular service, fixed no service / service provider crash issue.
Now the issue I am having now is it only charges while off and not while it's on.
While it's off it's 0.4A.
It was working before. Charging died after transceiver repair. Replaced Tristar and now am at this issue?
Could this be replacement Tristar being faulty?
Had to rebuild audio Ic circuit as components moved around when removing the metal shield for it but fixed that okay.
Tried another charging flex and battery.
What's strange about the phone is that it will not boot up without charging cable plugged in.
So I would have to unplug battery, then plug back in and plug charging cable in for it to boot.
Seems to be no Sim card install message being spammed on this phone, probably going to give up on this one.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
의견 추가하세요
답변 2개
선택된 해법
Hey Ben. Charging circuit issues can be a pain as there are lot's of IC's involved and some passives are spread out all over the place. You can never really be sure about Tristar so I would certainly try a new one. Tigris can also be an issue, especially if you applied a lot of heat on the radio IC's. Finally, working on the Audio IC may have impacted the PMIC, which is seriously underfilled.
However, with only 0.4A of current, check out L2300/C2300. Sometimes the carbon-like inductor separates partially from the contact point and therefore doesn't connect electrically properly and that will have a huge impact on current.
해당 답변은 도움이 되었습니까?
점수 3
의견 추가하세요
What happens when you try a wireless charging pad?
해당 답변은 도움이 되었습니까?
점수 0
댓글:
iPhone 6s does not support wireless charging.
Phones that support wireless charging as far as I know are iPhone 8, X and Samsung Galaxy S6 to s9.
의견 추가하세요
귀하의 답변을 추가하십시오
Ben 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 1,540
