2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1401 질문 전체 보기
My iPhone won't charge unless turned off
I have an Iphone 6 plus that I've had for about 2 years now. I recently got the screen and battery replaced in it last month and everything seemed to be working fine other than the touch disease it has. I was using my phone today like normal, but i noticed the battery getting low, so i tried to plug it up. The phone just wouldn't charge. I tried everything like cleaning the port, using different cables, wall adapters. Everything. The phone finally got so low that it turned off, but then it started charging again. It turned on and didn't charge past 2%. It's on a continuous cycle of dying and then charging to 2%/ If anyone know show to fix this, please let me know!!
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
3개의 답변
선택된 해법
There are a few possibilities here:
  1. It could be a bad replacement battery. There are a lot of poor quality batteries flooding the market (I changed the battery, calibrated: but it only worked for one day!).
  2. It could be related to the charging circuit. Are you using Apple original or MFi certified chargers and Lightning cables? Poor quality chargers, especially car chargers, can damage the charge circuit on the logic board.
해당 답변은 도움이 되었습니까?
점수 3
의견 추가하세요
Check and make sure that the battery connection is seated properly once I replaced the battery in my iphone 6 and the battery percentage was all over the place. I would try that and see if it works
Best regards, activoid
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
here what you should do :
  • Speedyfix Hecks ***
1- Plug the charger to your Phone.
2- Turn off your Phone or wait it to tun on if it’s already off ? then turn it off while keeping it plugged to the charger.
3- Wait about 5 sec then press the home button only, if the battery logo appears without the cable logo then it’s 100% charging.
4- Just keep to charge an hour or 2 then you can turn on your phone and you will see the difference ^^.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Kinsey Dennis 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 20
지난 7일: 176
지난 30일: 802
전체 시간: 6,517
