주요 콘텐츠로 건너뛰기
모델 A1286. 2011년 2월 출시 / 2.0, 2.2, 또는 2.3 GHz 쿼드-코어 Intel Core i7 프로세서
583 질문 전체 보기
Temperatur Improvement by replacing the Thermal Paste Some Values?
You Mentioned that it could be grate to replace the Termal Paste on these Models and use just the needed amount do you have run some tests how big the improvement in better CPU or GPU Temperatures really is on this model ?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
take a look at these.. arctic silver 5 is the generally used paste for these things, the manufacturers claims 3-12 degrees lowering..
http://www.arcticsilver.com/#
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
+ Nice way to answer. I normally use Arctic Silver 5, but everyone has their preference.
I used ceramique once but was unimpressed.. Swapped to no5 after a recommendation on here, I'd have to say it was easier to use and I've no complaints with the result on a few xbox 360 RROD. It's not a mac, but I'm sure Mayer uses it, in fact it may have been his recommendation!
+ that's 3-12 degrees lower than standard pastes. Yes I use the Arctic Silver. I didn't like the ceramique either.
댓글 달기
귀하의 답변을 추가하세요
Arne Glodde 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 2,311
