How to fix water damage?
I spilt tea on my phone and now the headphone jack things that it has headphones in when it doesn't so sound no longer works. Also the home button is broken however Touch ID works. Does anyone have any ideas.
좋은 질문 입니까?
좋은 질문 입니까?
Hi @helpmyphonedead ,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First do not turn on your phone and then you need to with the phone turned off, remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available at most pharmacies) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% or less, can contain scents and is not as effective. If you do check the label to verify the amount of IPA
Here is a couple of link that describes the process.
Repairing iPhone Liquid Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your phone.
If this process seems too daunting, take your phone to a reputable, professional phone repair service experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
해당 답변은 도움이 되었습니까?
I just had this exact same thing happen except dropped in toilet. First take flashlight the look in headphone jack, if there is white powder present, all i did was take a toothpick and poked and scraped the powder corrosion out. My sound now works
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 817
