주요 콘텐츠로 건너뛰기
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
426 질문 전체 보기
I spilled coffee in it about a month ago?
About a month ago, give or take some change, I was drinking coffee out of a red Solo cups, and for whatever reason, my apparently geniusness decided to put the cup on top of my Xbox. It spilled into the fan vent, I kinda panicked but since nothing really happened right away, I figured most of the liquid missed and hit the floor, well... More that what I thought got in there did just that. Long story short, I'm kinda stupid, took it apart, cleaned out the coffee with a rag (it had a lot of sugar, so I know that didn't help) and put it back together, which, in turn, made it worse. Now I'm lucky if I can even get it to load the initial Xbox screen. Sometimes I'll get all the way to my profile, then it'll shut itself off. Now I just use it as a charger box. Is there ANY way it might be salvageable, or is it the end for ol' sweet Chelsea? I also let it run WITH THE COFFEE IN IT, for about an hour, then it shut itself off. I still haven't put her back together completely, either. I still have hope, and I'd appreciate ANY help, even if it's just breaking bad news to me.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
does it show any signs of corrosion, if so use isopropyl alcohol stronger the better like 90 % range and a toothbrush and clean the corroded areas. where abouts are you located
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
DonVhanDüde 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 954
