메인 콘텐츠로 스킵하기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3886 질문 전체 보기
activation impossible after reset
my problem with my iphone 5S persists for 2 months. After a simple restoration to the State Factory, I find myself facing a blocked iphone impossible to activate either manually or with iTunes (a message related to a SIM card that appears).
I tried the Apple Support Tips on their site, and even put it in DFU mode and activate it from iTunes, but in vain :(
I have consulted two repairers who tell me that there is a problem motherboard and the other assumes that it is a Software problem !
ANY SOLUTION PLS ??
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글:
Hi,
"a message related to a SIM card that appears" : Coud you be more specific with the error description ?
의 답변
Hey;
( Disconnect iphone make sure that the sim card is well enclosed, and if you use a pin code of the sim; touch "unlock" to access and reconnect )
의 답변
arnarque et messonge
의 답변
Arnaque de Apple total réussite
의 답변
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
1개의 답변
선택된 해법
There is one simple thing you can try before concluding it’s a hardware issue:
If you put the SIM card in a different phone, check whether it’s recognized, and remove the pin code from it. Then insert it into the iPhone and try to activate. In some rare cases the sim won’t ask to unlock, which blocks the activation. Removing the sim pin circumvents this.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
My sim card is without a PIN code, and i've tried even with other sim card but in vain; this message is always posted on the screen : "
Your Iphone could not be activated because the activation server is temporarily unavailable. Try connecting your iphone to itunes to activate it or try again in two minutes. If the problem persists, contact Apple Support at apple.com/support"
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
noor 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 28
전체 시간: 582
