주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
473 질문 전체 보기
Laptop shuts down when disconnected from power at 60%
My mbp suddenly started shutting down around 51 to 61% battery when it is not connected to the power cord. The battery status shows that I need to service the battery, but it is no longer under warranty.
I've downloaded Coconut Battery to see my battery's condition, but I'm unsure what to make of it. I've downloaded Python Launder to run an application at log-in, but I get an error on the code I found online. The computer runs well when it's connected but I'm hoping to find a fix because I can't have it conneced all the time.
I've tried doing an SMC reset, but that did not fix the problem either. Any help would be greatly appreciated!!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
@bobneedshelp
Design Capacity is listed by Coconut battery at 18.9%. For something from 2014, it should be in at least the 80%s. This is indicative of a failed battery.
If you fix it yourself, it is $50-$60 for the battery. Please note, that some disassembly is required, and the battery is glued down to the underside of the palm rest.
Here is the teardown guide if you need it.
MacBook Pro 13" Retina Display Mid 2014 Repair
MacBook Pro 13" Retina Display Mid 2014 배터리 교체
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
I believe you have a bad battery. You could try sending it to Apple or buying a new one online or in stores, but other than that I’m not sure how to help.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Bob Ray Delgago 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 119
