Lines inside bottom half of television
My tv has some lines on the bottom of it, how much would it cost to fix it?
Model is KDL-40XBR4
좋은 질문 입니까?
Model is KDL-40XBR4
좋은 질문 입니까?
@mazino that will depend on what causes those lines. You are not giving us enough information to help you a whole lot. This sounds like a panel error and would be expensive since it is next to impossible to replace the LCD, but unless we can see if it will only be a guess. Post some images of what your screen displays with your question. Use this guide for that 기존 질문에 이미지 추가하기 Also, and this is very important. What is the exact model of your TV.
해당 답변은 도움이 되었습니까?
i have posted it
@mazino looks like a bad LCD panel. Sorry there is no repair for it. You will need to try to find a replacement for it. A new panel, if even available, will most likely cost more than your TV. Try to find a TV that uses the same panel but is broken other places and harvest the panel from there.
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 675
